ek ute dial up beware picture heavy
maginoodle
vy series2 ss crewman
Hi all,
this is my ek ute project.
plans are to put a buick in it and use it as a daily.
CANYONERO
Likes Cheese...
Country SA
V8 6spd wif MOMO leavaa.
wow, i like it :)
going to keep a close eye on this one.......... who knows might be callin on you to give us some tips in the future as i wouldnt mind takin on a similar project.
(always drempt of a V6 in a FB ute)
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
Terrific starting point for a pretty rare Holden these days. Good luck with the project - I will be watching for updates.
maginoodle
brought home the vn donor car today.
my mate gave it to me. he was going to use it as a donor for his hq tunna but decided to freshen up his 308instead.
i just finished for the day, i put the motor back in and wired it up. went to fire it and it wouldnt go, there was no power to the petrol pump, so i put a temp wire in to the relay and found that the pump is no good so i will try an get one tommorrow.
then i will start doin the wireing, i figure the warning lights,starter will be easy.
working out which wires for the relays etc will be the tricky bit.
Pub247
Melbourne S.E.
Ford Fairmont
love the ute mate i would have gone an ecotec but buick will do fine be watching this thread too
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
the plugs by the battery 6 pin one with clip facing up pin 1 F/P relay controll 2 too oil pressure sender 3 oil pressure sender output for fuelpump 4 ecu continous power 12v 6 injector power feed from relay.8 pin plug 1 brown at dfi 2 temp sender 3 oil sender for light 4not used 5 AC connects B8 at ecu 6 tacho feed also is same as green sprout at dfi 7 AC relay control 8 fan relay control.dash loom plug by ecu 1 from speedo 2 pink? ignition switched 12v 3 4th gear input 5 check engine light 6 trip comp 7 park/netral switch 8 TCC solinoid
Ado
Are we there yet?
vsII statesman L67
Gee i hope you can weld.
maginoodle
thanks delco, i need some clarification.
ok so i decided to use the vn harness instead of making my own. so i cut the vn harness out. undid all the tape. then i started at the easiest point wire 4 is done.
wire 1 F/P relay control is that the relay output 87 or the relay input 86? i am thinking 86.
wire 2 oil pressure sender- where does it go to? The oil light or something else?
wire 3- does it join to fuel pump relay pin 87? and do i have to put a 1 way diode on it?
wire 6- pin 87 fuel relay?
will do this part of harness before i go to the others
cheers shane
maginoodle
now i started on the 8 pin
1-brown dfi wire, what does it need +ve -ve or something else?
2-goes to temp in dash
3-goes to oil light in dash
4-none
5- ac, wont have one do i need to have it hooked to anything?
6-tacho- wont have one shouldnt need it.
7- ac control- shouldnt need it
8-tcc solenoid, what should that hook to?
the other plug at the ecu(is that the comp in left kick panel) had nothing hooked to it so i shouldnt need to touch that or the adld plug
cheers shane
