ek ute dial up beware picture heavy
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
these diagrams are easier to understand mate thank sammy for hosting them so i could grab them for you.as long as you have both the main power feeds to the ecu and pink switched and the relay feeding the dfi and injectors power and pump getting power you should be away
maginoodle
vy series2 ss crewman
thanks delco, i fed the pink wire in the corner of the bigger plug and it ran.
will post pics of my wireing job after i work on the warning light wires, so i can tape the loom up.
cheers shane
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
horay its alive LOL least your all good to wire it in now mate
maginoodle
Hi delco,
everything seems ok, still havent wired up everything.
i have the oil light wired in and the check eng light.
on the 6 pin do i need to wire in 2 and 3?one is orange and the other is purple.
where is the alt light wire, i think it is the brown wire with the starter solenoid wire but i am not getting either -ve or +ve to power the light from that wire.
on the plug at the ecu i have ign +ve going to pin 8 a pink wire (with a trace i think), you have it marked as tcc solenoid, pin 2 has the same colour wire so does it just supply the tcc with ign power?
cheers shane
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
6 pin plug 2 and 3 are the fuel pump backup you can leave it out if you want.what colour is the wire at the alternator you must have the plug by the ecu up the wrong way for my numbering thats why 2 and 8 are backwards LOLor i drew the other side of the plug theres only one pink going to the ecu
Sammy
44
Tenambit, NSW.
www.oldholdens.com
LH Torana with Ecotec V6
well i can tell you on the wiring i have in my gemini (commodore alternator) theres a white wire from the alternator that goes to battery +ve then the brown one goes to -ve on the light and the +ve for the light should be ignition powered....
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
by white are you referring to a second small wire or the big charging wire sammy
Sammy
44
Tenambit, NSW.
www.oldholdens.com
no the big wire is the red one ... the small one which is on the clip on plug with the brown wire is white, it goes to the battery via a fusable link (plug right near the battery terminal) and is just for voltage regulation i believe ... the important one :)
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
sweet as cheers
