Elec mirror / rear window de-fog heater
rynobyrnzy
Vs ute
Hi guys trying to fix my elec widows on my 97 VS ute. Checked fuse ok, grabbed another second hand switch with no luck both switches when put to driver side can hear a clicking sound from possible relay in the BCM can also feel it. so I swapped the BCM with a spare but same again? I can't start the car with the spare BCM due to key code not matched. So original BCM bak in. When on passenger side no relay clicking sound. Are there external relays from bcm can't seem to find them.
When mirror switch is on drivers side then toggle the adjustment switch the clicking sounds like its also from the driver door also almost like a central locking attempt.
Also the rear window de-fog is there a relay, checked the fuse its ok. No luck, any hints? Where abouts are the terminals That go to the window heater.? took off the plastic covers on driver/passenger side not there. Under ceiling...?
Last issues with the ute then it's off to regency for the defect inspection.
Cheers guys
Brett_jjj
Tamworth NSW
vs commodore
I dont think the utes had a read window demister.
rynobyrnzy
Vs ute
Ok, hm there are 3 switches on the centre consol/dash 1- ac. 1- hazard, and the third is a square box with 3 air/blowing strokes indicating air flow - I assumed this was rear widow de-defog
rynobyrnzy
Vs ute
Sorted the wiring issue, stripped the door skin and unplugged the loom under the dash pulled the loom out in between the door jam found wires cut in half from door pinching I gather. That fixed the mirror issue.
Now just some info if any one has a vs ute please tell me about the rear window defog demister does it exist there seems to be a switch there also is the black stuck on sticker like heater with dots from left to fight across the back window, from top to 4 inches down. Raised feeling if you rub your hand across it.
