Tonner Matt
- May 12, 2014
- 1,791
- 2,191
- 113
- Location
- Darwin
- VZ 1 Tonner LS1 M6
Last weekend I fitted a Sony MEX-N5200BT in my VZ Tonner
The issue I'm having is after turning the ignition off, the aerial will repeatedly go up and down about 6 inches
To get it to stop doing this I have to put the key in the ignition, turn it on to accessories and then turn the ignition off and remove the key again
The aerial then goes all the way up and then down, and stays down
If anyone else has had this happen before and could shed some light on it for me it would be much appreciated
The aerial also stays up when playing CD's, but apparently it's just a characteristic of the Sony stereos, so I am contemplating disconnecting the power to the aerial so it stays down all the time
Just to add...………
The stereo and all it's functions work fine
I replaced the power aerial a couple of years ago with a cheap aftermarket unit that has been working fine
I used Aerpro harness adaptors:
APP064
APP8SP3......As I never used the steering wheel controls with factory stereo anyway
APP064 primary harness was even wired correctly......Didn't have to swap the Red & Yellow wires to keep the stored radio stations
Just to add...………
APP064
