R
rattattack1313
Guest
Had a fun afternoon yesterday..Infusion bought a new electric antenna for his commo.........he wasnt sure on the installation, so he drove all the way to my place.... we 1st had to loosen the bottom of the guard, and ger rid of the plastic inner guard bit...... we could't take the guard right off, because we didn't want to damage the paintwork(and the screw heads were painted over).... stripped the console down, and removed the car computer out of its bracket......we then had to join the 2 antenna earth wires, and connect to the body...a convienient little screw up top with a bayonet clip ...yay!!!!Then we bent the mounting plate thing with all the holes on it, and put a nut & bolt through the wall......(remember removing the computer??? the nut lives behind it...).....a quick check to make sure it isnt hitting anything......then behind the head unit..... we stripped a little plastic from the yellow power wire.....taped up..connected the power wire from the antenna to the blue wire from rear of head unit.......jammed everything back in the hole it fell out of....and it even worked !!!! We done real goood !!!!!!!!!!!.So...if you like the idea of an elecrtic antenna...don't be shy..it takes a couple of hours fiddling about, especially if you have never done anything to your car like this.....but worth it, I think....... :thumbsup:
