vt_grn_mchn
hey guys, my vt previously had its windows converted to electric windows before i purchased it, the two front windows have been wired to the main switch, which controls them fine, they work all good, its the back windows im having problems with, i have taken the door panels off and tried to work out the problem, the motors both work fine when they get 12v they will go up or down depending whether the polarity is reversed or not, so i checked then whether the wiring is delivering 12v, and yes it is, 2 of the 3 cables are (im not sure what the 3rd is for) so i then tried connecting the pins to the switch, i can get the window to either go up or either go down but not both at the same time.. any suggestions or help would be greatly appreciated. thanks guys
