Electric window conversion
Markw78
46
Tamworth
Vr commodore ute
Hi guys,just put electric windows into a vr ute,everthing connected up,but it blows fuse 7 when you plug in the 5 pin relay under the dash?
BlackVXGTS
Melbourne, SE
Hmmm. Fuse F7 is the power door locks & radio fuse. Fuse F5 is the power windows fuse.
Markw78
46
Tamworth
Vr commodore ute
Yes but is linked from the relays
Markw78
46
Tamworth
Vr commodore ute
I must add,I'm not a auto electrician unfortunately
ephect
Donating Member
VS Acclaim V6
With the conversion you need to cut a green wire under the driver's side dash. I followed a JC thread years ago.
Also need a circuit breaker instead of a fuse in F5 socket.
Markw78
46
Tamworth
Vr commodore ute
A solid green wire?relating to the power window circuit?
ephect
Donating Member
VS Acclaim V6
Yup, trying to find the thread for you.
What did you follow to do the conversion?
ephect
Donating Member
VS Acclaim V6
ephect
Donating Member
VS Acclaim V6
