Electrical Issue - Battery or Alternator?
wildfiremaint
VR SS , 2007 Subaru LIBERTY Wagon
As Deuce said , the battery terminals are different sizes the negative being smaller. Buy them as a pair.
commodorev6
Australia
VS Calais V6
I've been monitoring the battery/car over the past few days. Today, it was at 9.0 volts. I charged the battery again for about 15 minutes today and it quickly reached 12.2 volts. As soon as I put the key into the ignition and turned the key, the voltage dropped instantly back to 8.7 volts within seconds. I haven't seen that voltage drop so quickly before.
losh1971
North Tas
VE Series I SS Ute
Yep, like I said the battery is cactus, you need a new one.
chrisp
Melbourne Victoria
VF2 MY16 SS Redline Sportwagon
A battery that flat has probably entered in to a ‘negative resistance’ region, put it back on the charger and leave it for a long time, the voltage will quickly go up (but the current will be low). As the battery charges it’ll ‘reform‘ and the voltage will drop and the current will go up. Leave it until the voltage comes up again (and the current tappers off).
Most likely, the battery is probably past it, but no harm in trying to charge it for a day or two and see if it comes back. Long term you’ll need a new battery.
gtrboyy
vt ss & lc gtr
Battery might have dead cell or low on water...could also be past use by date.
commodorev6
Australia
VS Calais V6
Yes, I agree @losh1971 , @chrisp and @gtrboyy. I wanted to be sure it was the battery not the alternator. Both batteries I tried in the car are over 5 years old. Now time to search for a new battery. The current battery is a 550CCA RACV Sealed type.
gtrboyy
vt ss & lc gtr
Go bigger cca...don't worry if heavier or tad more expensive.
As long as it has long warranty & put trickle charger on it to keep fully charged it will last years
losh1971
North Tas
VE Series I SS Ute
Don't know where you are located but if you're in Adelaide I can tell you the cheapest place to get a Century. If you're in Tas I can tell you the cheapest place to get a Supercharge, which are a really good battery.
commodorev6
Australia
VS Calais V6
@gtrboyy I noticed there is the Century Ultra Hi Performance Car Battery 67 MF with 640CCA. Can you recommend an affordable trickle charger?
commodorev6
Australia
VS Calais V6
@losh1971 thanks for that. I am located in Victoria. Both battery brands are well known so I will consider either.
