Electrical problem...
mischf
VN Executive S2
Hi my VN V6 has a strange problem where I get a whistling/whining noise from the engine bay sometimes and when I get this noise 2 things happen:
1 - All the lights on my dash are much brighter than usual. As soon as the whining stops the brightness goes back to normal.
2 - The engine cuts out if i put it in park or neutral or stop at the lights ie: it won't idle. If I start the engine when it's like this it will run for about 2 secs then die. Start it again it dies etc. I have to give it some gas to keep it running then put it in drive and it idles fine.
As soon as the noise disappears both problems go away. There is no performance loss.
Any ideas?
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
two problems
1/ your alternator is failing, get it fixed before it over charges & destroys the battery & any electronics in the car.
2/ IACV may be faulty, it may also be the voltage problems.
fix no1 first & see how it goes.
Rob
mischf
VN Executive S2
Does anyone know a good place to get my alternator reconditioned and whether the 85 amp bosch alternator from a V8 is the same as there's a new V8 one on eBay for $50. Thanks.
mischf
VN Executive S2
Oh i'm melbourne too.
mischf
VN Executive S2
Well i put a new regulator in (RE60) and its much better. My headlights were getting brighter as well, and the windscreen wipers were going nuts. Still makes a bit of a whistle though, i wonder what that is...
Tasmaniak
Not a valid input....
S.E. Melbourne
www.ranjinstallations.com.au
bearings in the alternator would be my guess.
ad45
VT wagon S2
are you an auto elec mate
Tasmaniak
S.E. Melbourne
worse..automotive elecTRONICS technician
mischf
VN Executive S2
