Mark17
hotrotor.17
- Nov 2, 2008
- 104
- 2
- 18
- Location
- sydney
- VE SV6 Ute 60th Ann
HI
Can anybody shed some light on VE electrical problems with my VE 08 SV6 Ute. While you are driving along all of a sudden the interior light comes on and you can't turn it off and the open door simble on the left hand side of the instrument panel stays on telling you your doors are open? but they are not. If you try to lock your car with the remote key the drivers door will not lock and then the car beeps 5 times and then the alarm goes off continuously till you try to open it manually. It takes 3 goes to manually lock the drivers side door and when it is locked manually it doesn't lock the hard tonnaue cover and the manual key won't lock it either ! All this only happens when driving in the rain.!!! When the rain stops 5-6 hours later everything goes back to normal. It is in at Holden warranty for the second time now and still waiting on the diagnois of the problem and o yes has a major oil leak either from the auto trans or the power steering I can't exactly see where it is coming from because of the under cover tray covering the problem. The oil what I can see is running either side of the front bumper bar and the engine cross member and getting into the drivers front inner wheel arch. The car has only done 5,000 klm. Any feed back on these two issues would be greatful I was told by a mechanic it could be the body control module on the electrical problem.
Mark:bang::bang:
Mark:bang::bang:
