Hi all,
I'm getting a 2100kg bar/hitch package fitted this week and maybe a Redarc Tow Pro (if required).
If I didn't use a brake controller with a trailer equipped with electronic brakes what exactly happens when brakes in car are applied?
I'm guessing you get the same trailer brake pressure (mid range) no matter what pressure your car brakes are receiving, only guessing though.
I've done plenty of towing, but only at work in large trucks with brake controllers so I'm clueless to everyday car towing.
Also, in regards to what I think Christov (on page 1 of this thread) was referring to, was the trailer sway control that the VF has.
So what happens when your plugged into a trailer with brakes and maybe have a brake controller?
Is the electronic sway control sending any info to the trailer and if not would the trailer brakes and controllers get in the road (so to speak) of the effectiveness of electronic sway control that the VF has, for example, if the sway control is bringing a trailer into line using different braking pressures to either 2 axels or 4 wheels (not sure) what info is it sending to the trailer brakes.
I guess to sum it up, are trailer brakes and/or brake controllers going to interfere with the VF's sway control.
Any comments and thoughts appreciated from Tow Masters or rookies like myself.
