Electronic oil pressure gauge
Chookz103
Western Australia
Ve ss
Wanting to fit electric oil pressure gauge to my VE Ute it’s a 6 litre
Can it be wired in with the current oil pressure unit or do I have to remove the original one and fit a tee piece and use both so the ecu recognises the old one
Deuce
Super Stock
'94 VR SS V8
I ran a remote filter (in a much easier to reach position) and ran the elec oil pressure sender from the remote mount also.
VR 355 sedan though
Chookz103
Western Australia
Ve ss
VR 355 sedan though
Yeah thanks might be a bit hard to do but thanks for the information
07GTS
Australia
VEGTS BUILT BLOWN E85
ecu needs the factory sensor, u would have to t-piece in or use the cooler fitting on the side u can get the thread adapters for them, or just get a scanner or some way to show/use the factory reading
Immortality
Staff member
Sth Auck, NZ
I love how far we have come, my 83 SL/E has oil pressure and voltage on the dash...
Chookz103
Western Australia
Ve ss
Thanks for the information, sounds good
VS 5.0
And when people can no longer see / monitor those things, guess where average Joe turns too when something goes wrong.........the local stealership.
shane_3800
35
places
vr commo
Why is that? Is it only for the oil light or does the car go into limp mode with no oil pressure? Oil light on is not a issue for "me" if I can see a pressure read out.
shane_3800
35
places
vr commo
Honestly it's not an issue these days. I just did a trade course and sitting there when David was talking about common problems I realised we don't actually get many at work. We get general service work or old **** boxes with major failures most common problems are under warranty so go to the stealership. We service a lot of fleet cars for the government and don't get any issues, likely to be less now with more hybrids comming in.
07GTS
Australia
factory sensor does pressure which are also for warnings so u get the low warnings which are set to a table of rpm v min pressure threshold which is handy to increase if u ask your tuner so u get an early warning as the factory level is pretty low, also u get the oil starvation safety feature as some are enabled
