Electronic Shift Kits
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Wagon_Wheel, Aug 16, 2006.
  1. Wagon_Wheel
    Wagon_Wheel Drop A Patch....
    Mt Martha, Vic
  2. Wagon_Wheel
    Mt Martha, Vic
  3. TheForgotten
    TheForgotten only human......
    quarantine
    VR EXEC
    read about them a while back. can't say they'd be any good if you want a neck snapping change, and I reckon it'll kill your trans a bit quicker
  4. Patrio7
    Patrio7 3Y3 K4N 5P33K 1337.
    Perth, Como
    '96 S1 VS Exec
    Pretty much it overrides the ECU's normal shift maps, the idea is its like powermode but kicking in harder.
    i personally would advise against it on a stock tranny and instead spend the $300 ish on a stage two shift kit for the transmission itself, normally comes with adjusted and reinforced parts and most places would give the transmission a play with to make sure nothing will go in a hurry, more reliable, stronger and better.
  5. stateo 304
    stateo 304 New Member
    1998 vs serries111 statesman 5.0
    i put one in my falcon it was good but didnt churp the wheels into second with the stock diff ration but when i put 4.11's in it it was good churped them into 2nd just get the stage 1 as with the stage2 which i had you can notoice the differance save you the $40 odd dollars, i put mine in there piritty easy come with very good instructions i got mine from www.shiftkits.com, i just got my stateo done by a automatics place they did a stage 2(mecanical) and corvette survo piston and its great but that was $330 the electric ones are deffently a good mod for there price
  6. Wagon_Wheel
    Mt Martha, Vic
    Hmmm...... Fair enough, im hearing good and bad points, i dunno, i guess ill see what happens then ey lol thanks guys
