I purchased Risolene rear main seal repair once. Made it a lot worse. Useless waste of money
Well you are mentioning a different part of the engine, he is discussing the cooling system.
The only way to fix a leaky rear main (engine oil) seal is the find the cause of the problem. There could be many causes.
One of them can be a combination of too much engine oil and built up pressure in the crank case which forces the engine oil past the rear main seal and that eventually kills it. So throwing Risolene Rear Main seal in that, won't fix anything. You have to replace that rear main seal.
If you have damaged the smooth surface on your crankshaft, eg. grooves in your crank shaft caused by grit in your engine oil getting between the rear main seal and the crank shaft, then the Risolene will sort that out and make that new rear main seal last longer, but you still have to address the cause of the problem being dirty engine oil full of metal grit and too much engine oil in a crank case that isn't venting through the PCV valves.
