Fun_Bucket
- Mar 23, 2009
- 2,990
- 9
- 0
- Age
- 38
- Location
- Cairns White Rock
- Cruze II sri
Ok, i come up with a list of questions, than i am unsure of the answers to. I've read quite a bit on the net, and now i know a lot more than i did when i started, but i still obviously have a loooooong way to go!
1- Does it matter where i put the ports on a box, in relation to where the sub is mounted
2- How does the positioning of the sub in the boot, and the direction it fires affect it's SPL levels
3-If maxuimum SPL is the target, should the inside of the box be dampened.
4-Can the use of Polyfill on a Ported enclosure, increase volume levels
5 With my Head Unit, i have some options with the Sub settings, 30,50,60,80,and 120hz. And also normal and rev- The best i could get out of it before, was set at 80hz, in rev mode...But adjusting the HZ setting, had almost no affect on the sound at all.
6-In full pass mode on my amp, there is a tuning adjustment for the HZ, which goes as low as 30hz, or should it just be run on LPF? I realise it's a lot of questions, so thank you heaps to anyone that can answer even just one of them. And also a big thank you to Stone X and Calais Cruzin for your help with this so far.
