engine bay help
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Greggles_VS, Jul 25, 2012.
  1. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    If i put a 12mm spacer under my plenum and a 12mm spacer under my inlet manifold, will it affect or improve my ride? Also do i need a gasket top and bottom of both spacers?
    What size o-ring is on my IAC as mine is perished and disappeared?
    What are the best engine mounts to get and where would you recommend getting them from? (Im from adelaide)
    If i install the mace airbox with inbuilt pod filter, is it recommended to get, a MAFless tune, a recon MAF or an 85mm MAF?
    Once plenum is off, is it safe to remove the plenum lid to clean inside? And what is safe to clean it with? E.g degreaser or TB cleaner. Same question for inlet manifold, whats it safe to clean with?
    Is it best to clean the inside of my rocker covers and do custom paint on exterior, or buy alloy rocker covers?
    Is there any "high quality" or "performance" water pumps, or is a standard one suffice?
    Im sure ill think of more but help on these questions would be great.
  2. seq4x4
    seq4x4 New Member
    Sunshine Coast, Queensland
    VS
    Better torque and fuel eco. Youll use gasket goo and new rubber gaskets for the lid and plenum.
    Take the IAC into a shop and find one that fits.
    Standard engine mounts are fine. Ebay those.
    Leaving the maf in is fine. Only go a bigger maf if your going a bigger TB. Mafless for show or F/I set ups.
    You can take the plenum off, clean it all with TB/carby cleaner. Also do your PCV valve. If you take your inlet manifold off youll need new oil and coolent as well as new gaskets.
    Wouldnt bother cleaning the under side of the rocker covers. Paint or alloy, its up to you how you spend your money.
    Standard water pump is fine.
  3. Greggles_VS
    Is there any pros or cons to using a v8 IAC on a v6?
  4. seq4x4
    seq4x4 New Member
    VS
    That IAC also fits:
    Holden Commodore VG Ute 6 Cyl, 3.8L 8/88-10/91
    Holden Commodore VG Ute 8 Cyl, 5.0L 11/90-11/91
    Holden Commodore VL Group A 8 Cyl, 5.0L 2/88-12/88
    Holden Commodore VN 6 Cyl, 3.8L 8/88-10/91
    Holden Commodore VN 8 Cyl, 5.0L 8/88-10/91
    Holden Commodore VN Group A 8 Cyl, 5.0L 6/91-12/91
    Holden Commodore VP 6 Cyl, 3.8L 11/91-7/93
    Holden Commodore VP 8 Cyl, 5.0L 11/91-1/93
    Holden Commodore VP Ute 6 Cyl, 3.8L 11/91-7/93
    Holden Commodore VP Ute 8 Cyl, 5.0L 11/91-1/93
    Holden Commodore VR 6 Cyl, 3.8L 6/93-4/95
    Holden Commodore VR 8 Cyl, 5.0L 6/93-4/95
    Holden Commodore VR Ute 6 Cyl, 3.8L 6/93-4/95
    Holden Commodore VR Ute 8 Cyl, 5.0L 6/93-4/95
    Holden Commodore VS 6 Cyl, 3.8L 5/95-8/97
    Holden Commodore VS 6 Cyl, 3.8L 1/96-8/97 S/Charged
    Holden Commodore VS 8 Cyl, 5.0L 5/95-8/97
    Holden Commodore VS 8 Cyl, 5.7L 5/95-8/97 (not LS1)
    Holden Commodore VS Ute 6 Cyl, 3.8L 7/95-7/00
    Holden Commodore VS Ute 8 Cyl, 5.0L 7/95-7/00
    Holden Commodore VTI 6 Cyl, 3.8L 9/97-5/99
    Holden Commodore VTI 6 Cyl, 3.8L 9/97-5/99 S/Charged
    Holden Commodore VTI 8 Cyl, 5.0L 9/97-5/99
    Holden Commodore VTI 8 Cyi, 5.7L 9/97-5/99 (not LS1)
    Holden Commodore VTII 6 Cyl, 3.8L 6/99-8/00
    Holden Commodore VTII 6 Cyl, 3.8L 6/99-8/00 S/Charged
    Holden Commodore VX 6 Cyl, 3.8L 9/00-8/02 S/Charged
    Holden Camira JE 4 Cyl, 2.0L 4/87-9/89 PFi , 20JD
    Holden Frontera UT 4 Cyl, 2.2L 4/99 onwards X22SE
    Holden Rodeo TF 4 Cyl, 2.2L 7/99-03 C22NE
    Holden Statesman VQ 6 Cyl, 3.8L 11/91-2/94
    Holden Statesman VQ 8 Cyl, 5.0L 3/90-2/94
    Holden Statesman VR 6 Cyl, 3.8L 6/93-4/95
    Holden Statesman VR 8 Cyl, 5.0L 6/93-4/95
    Holden Statesman VS 6 Cyl, 3.8L 5/95-5/99
    Holden Statesman VS 6 Cyl, 3.8L 5/95-5/99 S/Charged
    Holden Statesman VS 8 Cyl, 5.0L 5/95-5/99
    Holden Statesman WH 6 Cyl, 3.8L 6/99-9/00 (S/Charged - Upto VIN # L638720)
    Nissan Pulsar N13 4 Cyl, 1.8L 8/87-10/92 Mpi , 18LE
    Toyota Lexcen VN 6 Cyl, 3.8L 8/88-10/91
    Toyota Lexcen VP 6 Cyl, 3.8L 11/91-7/93
    Toyota Lexcen VR 6 Cyl, 3.8L 6/93-4/95
    Toyota Lexcen VS 6 Cyl, 3.8L 5/95-8/97
  5. Greggles_VS
    So in theory, they are the exact same module, just being listed as a v8 part even though they fit the v6? Stupid manufacturers lol
