Engine conversion question
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jwaye2, Sep 19, 2011.
  1. jwaye2
    jwaye2 New Member
    Darwin
    VZ Alloytec Sedan, VS L67 Ute
    hi
    I am thinking of putting my mates engine from his written off VT into my vs Ute. Only thing is that the VT is an auto and my VS ute is a manual. Im just wandering if anyone know of any problems i may run into putting the auto engine into a manual. any help would be greatly appreciated
  2. 304runner
    304runner ( .Y. )
    Central Coast NSW
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Nothing.. Should be a straight swap if its just the engine your changing.....
  3. vrutemarcus
    vrutemarcus New Member
    south australia
    1993 vr ute s pack
    all you need to change is the manual ECU
  4. Wombles
    Wombles Cars cost too much.
    Might need to change dowels as well.
    They're to locate the transmission properly.
  5. FstStig
    FstStig Diagnostician
    Central Coast, NSW
    2010 VE SV6
    Make sure you change over your Plenum as well. The VT's use a EGR system, VS don't.
  6. MADDNE33
    MADDNE33 New Member
    1999 vs ute series 3
    Will be a straight swap but make sure u change over the upper plenum with EGR like said. You dont want that and your vs loom won't have the plug for it. Dowels are not a must but defintly worth doing while its out. Also make sure you use new flywheel bolts as they are torque to stretch as there tightened.
    Good luck
