engine cooling
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by kenbo, Sep 30, 2011.
  1. kenbo
    kenbo New Member
    newborough
    vt s2
    Hello everyone, this is my first visit to your site, very interesting problems and solutions. I have just purchased a 2000 vt s2 model, driving home from the city I noticed the temperature gauge at 1/4 then once on the freeway it actually dropped to zero, remaining at this point for a few kms, I pulled over and popped the bonnet, felt the radiator which was cold, car seemed to run normal - not sure if this is the norm. Should this be a problem, what steps do I take to correct the situation. cheers Kenbo
  2. petergl67
    petergl67 New Member
    delahey
    holden commodore super 6
    How many kms. I have done 160000 and I ha to do thermostat radiator and new hoses when my car done a similar thing. It sounds like thermostat. Just keep an eye on ur temp.
  3. GRPABT1
    GRPABT1 Jakstas' Warden
    The ville
    VN shitta
    Is there actually coolant in the radiator? If yes then is there a thermostat in the thermostat housing? If yes is the water pump in good working order? If yes then it's probably the coolant temp sender.
  4. Cameron P
    Cameron P New Member
    Quakers Hill, NSW
    REDHOT VX SS
    Lol I think If he didn't have coolant he would be posting a thread about an engine replacement. Or the temp gauge sitting at hot
  5. kenbo
    kenbo New Member
    newborough
    vt s2
    thanks mate, will check out thermostat, as there is coolant in radiator
  6. kenbo
    kenbo New Member
    newborough
    vt s2
    thanks mate, will check out thermostat to start with, then perhaps the coolant temp sender.
