engine cuts out when getting warm
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by kniever, Apr 7, 2007.
  1. kniever
    kniever Active Member
    greensy, melb
    VY II Calais L67 & VN II Calais T5 5ltr
    hey all,
    my mate has a vn v6 calais with a vp engine in it and he is having a problem with it that it cuts out and runs rough when it starts to get a bit warm.
    on start up the car runs/idle's perfect but when the temp gets to about a 1/4 on the gauge it starts to run a bit rough and when u give it a few revs it backfires a few time then it cuts out.
    any help would be great, thanks in advance
  2. yZoH
    S/E Subs, Melb
    (0.o')
    Crank angle sensor...
    MaT
  3. kniever
    greensy, melb
    ok cool, what exactly is crank angle sensor and where is it?
  4. [JUDGE]
    [JUDGE] New Member
    South australia , Adelaide
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    lmao straight out the crank angle sensor its behind the harmonic balancer once its had its days when it becomes hot the car wont start after being driven for a while or even stall at times i had a stuffed one for ages didnt know what the problem was until i joined this forum :) thx guys lol, dad didnt even know of the CAS or herd of it, i just bought a second hand one fitted and installed for $70ish havent had any problems since.
  5. Matt_vp
    Matt_vp Donating Member
    Gladstone Qld
    vy lumina v6 A4
    the crank angle sensor is behind the harmonic balancer on the right hand side look into the engine bay, a good way to tell if that is the problem is pour cold water over it and try to start it, when it cuts out and won't start. if it starts then that is the problem if it doesn't the u should start looking else where like dfi unit, coil packs, or fuel pump, find out if it has spark and fuel..
  6. kniever
    greensy, melb
    so what exactly it look like so i can get 1 for my mate without going to the wreckers and going ''ummm that might be it, or maybe that'' and i cant run down stairs atm to have a look as i got a v8 not a v6
  7. kniever
    greensy, melb
    thanks matt_vp, forget my last post as you explained it good for me
  8. Matt_vp
    Gladstone Qld
    vy lumina v6 A4
    its on the right hand side of the harmonic balancer about level with the centre bolt but u would have to pull the balancer off to see it proply try the cold water test and make sure thats what it is..
    Matt
    edit... yeh didnt see the post above but thats where it is, good luck
    kniever likes this.
  9. VNexecutive
    VNexecutive New Member
    VN Calais 5L
    picture if it helps.
      File size:
      78.4 KB
      190
  10. kniever
    greensy, melb
    thanks heap for the help fellas and i knew the bottom big roung wheel was the harmonic balancer cos my mate tried to say it was the top little 1 like in that photo
  11. Matt_vp
    Gladstone Qld
    vy lumina v6 A4
    the smaller pully above the harmonic balancer is the water pump pully.
