engine cuts out
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by al2, Sep 11, 2006.
  1. al2
    al2 Guest
    i got a 98 vt wagon that sometimes the engine cuts out for know reason , can anyone help thanks
  2. don0xer
    don0xer Member
    2000 VX Calais 3.8L Supercharged
    Pls be more specific when saying it just cuts out :p
    were you just starting the car up first thing in the morning?
    were you just driving normally down the street?
    were you hammering it TLGP style?
    was there any noises from exhaust/engine area before it cut out?
    have you had a service recently?
  3. al2
    al2 Guest
    driving normally then cuts out can start it again after min or so , serviced every six months , engine can surge sometimes
  4. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    i had that prob ages ago was told it was the crank angle sensor i think its called 1 way 2 test 2 see if it is, is wen it cuts out pour some water on it n it should start straight away if not its somthing else.
  5. don0xer
    don0xer Member
    Yeah, same prob also - water does the trick 99% of the time :) holden quoted me $110 for the sensor, on ebay they go for $40. Im not sure whether its the cam+crank sensor but either sensor is about $110 to replace :(
  6. ProphetVX
    ProphetVX New Member
    Cronulla, NSW
    A Pushie
    I know this may sound stupid, however if what was mentioned earlier does not help. Is your key damaged at all? I had a little chip off the top of my key and suffered the same symptoms as you. Car would start fine, then randomly turn off. Replaced the key and haven't had any issues since.
  7. don0xer
    don0xer Member
    My keys fine, same with the spare which is is even better condition. But ive been told if tipping some water over the sensor fixxes it 99% of the time when its having trouble starting, 99% sure its gonna be the sensor... which so happens to be a more expensive replacement :(
  8. al2
    al2 Guest
    thanks for the help ,getting it checked on thursday
  9. al2
    al2 Guest
    turned out to be a blown headgasket
  10. Trevor 062
    Trevor 062 Member
    St Clair
    2012 VE S2 SSV REDLINE & 07 VZ ACCLAIM WAGON
    Sounds Expensive..Get a 2nd opinion..
  11. al2
    al2 Guest
    i got the crankcase sensor changed , now engine oil is leaking from around the back of the crankcase pulley ???
