Engine Fan
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by COMMY VP 666, Jan 18, 2009.
  1. COMMY VP 666
    COMMY VP 666 COMMY VP V6
    COMMODORE VP
    hey would anyone know why my engine fan is not working, no power at the connection plug for the fan, and i tested that the fan works and it does
  2. Pimpn1
    Pimpn1 New Member
    Adelaide, SA
    None
  3. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    relay, fuse, maybe burnt out wire. iirc it will only come on at certain heat levels and also when the air con is on. also it cuts out at certain speeds.
  4. centy
    centy Member
    Vp series 2
    yeah fan only comes on some times.
    run it for about 10 min on a warm day and wait.
  5. COMMY VP 666
    COMMODORE VP
    will do thanks guys, could it also be there thermostat?
  6. stocky
    stocky New Member
    you could also setup a thermo bypass switch and see if you can turn it on yourself
  7. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    It's turned on by the ecu, and the ecu gets temp readings from the temp sensor. So if all else fails try replacing the temp sensor at a last resort.
  8. COMMY VP 666
    COMMODORE VP
    is a temp sensor same thing as a thermostat?
  9. Morton
    Morton For external use only
    Fairstar the Funship
    thermostat = valve that opens to let coolant into your radiator
    coolant temp sensor = tells your ecu how hot water is BEFORE the thermostat (thermostat function not related to coolant temp sensor function)
    water temp sender = tells your dashboard what temp to display
  10. Paiste402
    Paiste402 My workin on the car face
    Normanville SA
    1992 EB Fairmont Ghia
    my bro's vn thermo fan stopped workin so i just made a switch for him inside the car. Basically its hooked up straight to the battery with the switch cutting off the positive wire. Works a treat.
  11. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    Hope you fused this wire?
    For those looking to install a switch to your thermo fan look at the how-to its pretty straight forward.
    http://forums.justcommodores.com.au...s/53659-how-fit-thermo-fan-bypass-switch.html
