Engine Knocking Bad! please help
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Aussie_Hustler, Jul 9, 2012.
  1. Aussie_Hustler
    Aussie_Hustler Member
    VS Ute Series III 1999
    hey guys recently was driving and car died on me and nearly didint start for no reason drove back home only to realise that some wires from the crank where hitting the belt so was short curcuting**, bought new battery and started her up after fixing and now there is a really bad knocking nice could it be valve spring or something like that or is my engine BUGGERED!?
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    It could be the harmonic balancer moving around causing the knocking. If its got any movement in it at all, its stuffed and will need replacing. You need to remove the belt to check the balancer for movement. It could also be the reason the CAS wiring ended up hitting the belt.
  3. Aussie_Hustler
    harmonic balancer isnt moving at all the knocking sound is coming out of the very top of the engine like a bolt is lose flying around in there...., a very big bolt
  4. Brett_jjj
    Tamworth NSW
    vs commodore
    If its not anything external like the balancer, then the engine is probably stuffed if its making that much of a noise internally.
  5. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    sounds bad, but also could be belt tensioner? ive herd they can cause a bad knock when ####ed and can throw belt off etc, worth a shot, take the belt off and start car, if its still there its internal if not check all drive pulleys etc
  6. Aussie_Hustler
    will give it a shot cheers guyz
  7. sam_commodore
    sam_commodore New Member
    Commodore VZ
    i am having similar knocking noise. its just happening randomly today.... i am worried abt my engine...
