ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
jamierawr88
Sv6 Ve 2007 & Calais VE 2007
lately those lights have been turning on on my dashboard then back off after awhile, excluding the oil light at that time, untill recently when all of those lights turned on on my dash board including the oil light and the temp gauge stopped working but none of them would turn back off,
would any of yous know what the problem for this to be?
i have a 1998 Holden VT commodore acclaim Seaden, also the alternator has been recently replaced in it too due to the old one being fried
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
They are usually the symptoms of a faulty ABS module. It might just be a bad connection, try unplugging the module and cleaning the terminals with a spray contact cleaner (available at Dick Smith, Jaycar etc.). This might help but don't count on it. It is a common problem.
jamierawr88
yea i tried it all but it still didnt work so i just sold the car off and got my self a Holden Commodore Sv6 Ve 07, lol
Ramsey82
1998 Acclaim
Jamie, I fixed my ABS module yesterday to a degree. I unplugged it, re-soldered the pins in the back as the dry solder had worn and become brittle. I had Engine, ABS, Trac Off, and Oil lights all on and now I have just the ABS and Trac Off lights on....so I've done something right so far.
Maybe someone else who has done this can explain it better to you, but I hope this helps a little.
11gothevt11
99 VT Sedan
I have same problem but only abs and trac off lights go on
If you ever find out how to fix it please pm me
cheers:bomb:
11gothevt11
99 VT Sedan
abs and trac control light on????
Hi there
I have Vt commodore
When i'm driving the abs and trac lights come on???
Also my trac control button doesn't work
what is common part to fail the button or the module??
Can :bow:anyone please help me
vtwagonjoe
VT Wagon
11gothevt11, im having the same problem.
Ive replaced my ABS module, and it hasnt fixed the problem at all. :(
11gothevt11
99 VT Sedan
Hmm to many commputers and sensors in these cars!
Also does your traction control button not work???
I need to get it working to have more fun
If you do ever find the problem pm me please
vtwagonjoe
VT Wagon
Rpm drops then picks up again, then the TRAC OFF light appears. Cant turn the trac control on or off after that until i turn the ignition off then back on again.
