Mine has started the same. I did the batt reset but now it wont clear at all.So, started my SS this morning and straight away found that estability control off followed with the engine light on, a few seconds later the engine light started flashing with the engine running very rough. I switched it off and started again same thing. Drove to work with the engine light flashing by the time i reached work the engine light went away with roughness gone too, however, the ESP off stayed illuminated even though i tried turning it on/off did not work.
To reset the system i unplugged the battery and started the car again at work and things were fine, now I am a bit worried why the light was flashing and disappeared would I have caused any harm to the motor with flashing engine light???
Any suggestions or solutions will be really appreciated guys...
Ok Borrowed a Tester, discovered po202 Cylinder 2 injector open circuit. I believe c 2 is front drivers side. wonder if injector 2 has Rip.
Thx, injector 2 had an open circuit failure. Swapped it with cylinder 1 fault followed injectorP0202 indicates that the ECM has detected a malfunction for the cylinder 2 injector circuit. The code is set once the ECM detects out-of-range voltage or resistance. The malfunction causes the ECM to set a Check Engine Light and may enter into failsafe mode. This failsafe mode is to protect the vehicle from further damage.
Thx, turned out to be open circuit in injector itself, new one, all good again.i had this happened and it was my tyre pressure pumped them up and all good. .check your wheel sensors as well
