trying using permatex no 3 liquid sealant, better for high temps/coolant, the rtv silicone is better suited for oil leaks. also small coolant stain is ok around housing if your not loosing any coolant, the alloy housing is usually not so flat and the gasket is thin hence the small dribble stain, sand the manifold/thermo housing flat and/or use 2 gaskets for better sealing or buy thick paper gasket and make your own like I do. Also the permatex allows you to reuse the gasket again if you have issues and need to take housing off.Thanks for the feedback everyone. Does anyone know what this green wire does? As you can see the thermostat housing has some coolant leaking slightly so that will need to be removed and a new gasket and Permatex RTV Silicone Gasket Maker, Multi-Purpose - Ultra Blue to seal it.
Can that green wire be unplugged? Its a fragile plastic clip. If this is the issue and a replacement is required where would I be able to purchase a replacement?
Also in your pic if that coolant temperature sensor in the housing below thermo is gone, engine light is trigered by ecu/pcm thinking temps/engine is overheating to prevent it being cooked.Thanks for the feedback everyone. Does anyone know what this green wire does? As you can see the thermostat housing has some coolant leaking slightly so that will need to be removed and a new gasket and Permatex RTV Silicone Gasket Maker, Multi-Purpose - Ultra Blue to seal it.
