i just had to put a new radiator in the vt and while i was at it i gave the engine a degrease, everything is all in nice and tight with no leaks but the engine light just stays on now and i got all these codes, -23 Air temperature sensor (voltage high) -32 Air flow sensor (voltage out of range) -46 Crank angle reference signal (engine will not start) -47 Crank angle reference signal (no signal) -73 Pressure Control Solenoid Current im sorta guessing a couple will go away when the engine dries properly like the 46 & 47 ones, but can anyone tell me what they mean and how to fix them?
well ive driven the vt to work and home again today and all the codes are gone except 32 & 73 and the engine light will still not turn off so its got me stumped
the plug from the air flow sensor (that square thing in the middle of the piping leading to the t/b) or whatever its called was diconnected which is what made the engine light stay on, its always some of the easiest little things that you forget to do.
