Engine loom connection
Pumba83
41
Bunbury
1998 vt s-pack supercharged
Hi folks
I've recently dropped my fresh built super 6 back in the vt but I've forgotten where most loom connections go cos it's been a while. I had photos on my iPhone but my darling son has reset default settings and I lost everything. This has probably been done to death but any schematics or drawings/photos would be muchly appreciated
Pumba
Pumba83
41
Bunbury
Hmm no help don't really wanna wing it
M
mwb235
Guest
Send me a PM with an email address & i'll send you an engine/PCM wiring diagram (if i try posting it here it'll be too blurry to read)
0081
VY s m5 supercharged
Just place the loom on the motor and it should fit and the plugs should fall near the sensor,
also I'm sure most plugs will only fit into the sensor its for. both knock sensors will have the same plug as will the injectors will have the same plugs but you should see where they go quite easy
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
As above, the plugs will go where they fit. There will be left over plugs as well. Unless you totally removed the loom, then all the plugs will be pretty close to their respective connectors.
