Engine mount install!!!!!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Joey_21, Apr 27, 2007.
  1. Joey_21
    Joey_21 New Member
    Western Suburbs
    VY SV8 HBD---mmmm LS1
    how much am i lookin at 4 installing an engine mount labour costs im after 2 change one side as i already have the mount any ideas or people done it let me know
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    should be round 100-200 i would think..
    involved: undo mount nuts. raise motor, remove, replace, drop motor, tighten nuts.. BAM :D all done
    (i believe thats right) plese correct me if im wrong
  3. Joey_21
    Joey_21 New Member
    Western Suburbs
    far out if only i had a crane wats so hard bout that u dont even have 2 lift motor out undo a few clips
    100-200 bux jesus
  4. Joey_21
    Joey_21 New Member
    Western Suburbs
    wat happens if i leave it with a battered engine mount long term effects????
  5. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Air con compressor has to be unbolted on the passenger side, and the power steering pump on the drivers side.
    If you leave it, the engine jumps around and you could do a centre bearing in the tail shaft. The exhaust will start leaking, the sump will end up touching the K frame.
  6. Joey_21
    Joey_21 New Member
    Western Suburbs
    zorst leakin wat u mean ???leakin air
    and i think my sumthings hits K frame now i got the part jus gotta go get it put in now
  7. Joey_21
    Joey_21 New Member
    Western Suburbs
  8. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    If the exhaust hits the k frame, the big piece of steel under your engine, where the exhaust pipe meets the manifold will come loose and start to leak. It leaks exhaust gas, not air.
  9. Joey_21
    Joey_21 New Member
    Western Suburbs
    any symtoms 2 let me know if this is happening???
  10. -UNKNOWN-
    -UNKNOWN- New Member
    S.A. The revenue state!
    '95 VR S2 BT1 5 Speed, N13 Pulsar Vector
    Add alot of cursing in between and your spot on!
  11. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    You asked what could happen if they aren't replaced. This is what could happen. I didn't say it would be happening now.
    To check it. get a piece of garden hose and use it as a stethoscope to listen around the manifolds and flanges for leaks. You will hear it flutter back up through the hose.
  12. Joey_21
    Joey_21 New Member
    Western Suburbs
    ok cheers mate thanks 4 ur help il get it replaced soon its only been a few weeks that its been playn up ever since i put my extractors in so i don no
  13. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Since you have extractors, there are no manifolds but they can still leak around the flanges where the Y pipe connects.
