Engine Mounting
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by REWIRED, Nov 16, 2008.
  1. REWIRED
    REWIRED New Member
    VR Exec II
    Hello Everyone.
    Im dropping a rebuilt v6 into my vr series II. The left mount goes in nice and smooth but the studs on the right side mount will not line up. Iv twisted turned, pulled, lifted, lowered the motor in every angle u can think of but to no success. I have had a poke around on this forum with the search tool only to find its not a very pleasent job to undertake. So if u have done this and would like to post some hints, tricks, advice, photos i would appreciate anything. Im going to try and undo half of the mount, line up the studs then use the engine mount bolts to alighn the mount back to the block.
    -Rewired
  2. REWIRED
    REWIRED New Member
    VR Exec II
    ^^ worked perfectly, cya's on the highway.
    -Rewired
  3. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    or you can just stick a bar in and go PUSH!
  4. REWIRED
    REWIRED New Member
    VR Exec II
    i found that the motor would not budge far enough even with my crowbar.
    -Rewired
  5. DannyboyDS
    VS Berlina
    not the motor, the mount :p
  6. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    its easier with the mounts bolted onto the motor and lower it onto the kframe
  7. DannyboyDS
    VS Berlina
    Thats how I do it, although 90% of the time one mount will go in and the other will be 1/2 an inch or so out, so a bar on the bolts and a shove and POP all done.
  8. VSIIBerlinaL67
    VSIIBerlinaL67 New Member
    VX SS M6
    cant be done with both mounts on the motor the left one needs to be on the k frame first.
    i had the same prob
  9. Pub247
    Melbourne S.E.
    Ford Fairmont
    sometimes if your lucky when you let the weight off it will drop in by itself but with the mounts on is way to go
  10. Cheap6
    Cheap6 New Member
    VP Exec
    Yep, leave the mounts attached to the engine. The trick is to drop one side in, it doesn't matter much which, start the nuts on that side and lift/roll the engine so that the studs for the other side just rest on the engine mount pad on the K-member. Then use a screwdriver angled between the studs to twist and pull one stud into its hole. The other stud can then be twisted into place using the first stud as a pivot point for the screwdriver. It's made easier if the screwdriver is close to the base (mount end) of the stud you don't want to move and close to the K-member end of the stud you do. The engine will drop into place so no fingers between the mount and the K-member.
  11. VSIIBerlinaL67
    VX SS M6
    must be different with ecotec then cause i tried everything scared of breaking the mounts so undid one put it on the k-frame first and went straight in.
  12. Cheap6
    Cheap6 New Member
    VP Exec
    There is a knack to it but it will work on Ecotech also.
  13. DannyboyDS
    VS Berlina
    haha, them mounts are pretty tough, and the bolts are damn near impossible to strip.
    Having said that, set out to do it and you will.
  14. yZoH
    S/E Subs, Melb
    (0.o')
    I lower it down with both mounts on motor, Put a ratchet tiedown around driverside mount, ratchet it an pops right in, 5mins work to save hours of torture....
    MaT
