Engine not straight
Jparr97
Vz 5.7l SS
I recently bought a vcm otr for my 04 vz ss, and the engine is not aligned with the center of the frame, it is off to the passanger side a bit. The mounts are good holding tight and level. Any help would be great
Fu Manchu
WA.
Has the car got a crash history? Maybe the chassis is off?
Vin999
SA
VSedanS
Good point mate, I had similar issue with old car with an engine mount breaking, turned out to be a front end crash damage fix, also the radiator plastic casing cracked with thermo fan shroud mounting points on the same side.
Jparr97
Vz 5.7l SS
No got a clean history with the car. Bought it from a dealer about a year ago and it has only had one previous owner.
Jparr97
Vz 5.7l SS
The engine is sitting about 5cm closer to the passanger side when i measure it from the TB to the guard back of the engine is of by about 2cm from center of inlet manifold to the strut tops
VS 5.0
The dealer confirmed it had never been in an accident ?
vr304
Auckland, New Zealand
2007 ssv manual
I remember seeing on YouTube, the skid factory videos he said manufacturers do offset engines to either side sometimes to help with space, fitment etc and it doesn’t make any difference compared with having the engine perfectly centred
Brettly-2008
Vasse
SS Commodore - Ford Territory ... both camps
I vaguely remember hearing all the iron block V6s from VN to VY were slightly offset. Cant confirm right now. As said, doesn't affect much... except the fitment of OTRs apparently.
Fu Manchu
WA.
Loosen off the Kframe and reposition the K frame to centre everything?
