Engine oil for VY v6
stick3
newcastle nsw
vz sedan vs ute gsx1400
supercheap have a list of oils in a book that is suitable for your engine
mirrabucca
72
VX S pack (Devil Yellow)
I used shell helix forever. 10W 30 I think.
I changed because I read that a thicker oil would quieten noisy lifters It didn't. I eventually went back to the helix. Better, but not 100%.
I then gave the engine a decent oil flush. Now back to 10W 30 and lifter noise has all but gone. It has 340,000 k's on it. I have owned since 17,000 (less than a year old).
To flush it, I bought a quanilty oil flush (nulon) and followed the instructions to the letter.
Except at the end. Instead replacing the filter and refilling with the correct oil, I didn't replace the filter (yet) and I refilled with a 5W oil I had lying around. I used that to flush the rest of the black oil residue out after the first flush.
Let it warm up , let it idle for 10 - 15 minutes. Then drained the 5W (now black) oil and replaced the filter. Fill with the correct grade of oil.
After about 3,000 k's the oil was still honey coloured and the engine is quiet (by ecotech standards!)
Heavy oils can clog the fine orifices in the lifters and make the noise worse.
Whiteshark68
Queensland
VY Berlina Series II
use a 50 grade
At 113 000 km's the car will not need any sort of 50 grade oil not unless the motor is rattling it's head off at the most it would require a 15w/40 or 10w/30 oil just go the best oil in the brand you prefer to use.
stick3
newcastle nsw
holden only used 20/50 in both v6/v8 upto vts2 and with the ls1 v8 and that used the lighter oil so they put the same oil in the v6 less hassle for the dealers
Panda69
Mollymook NSW
2014 VF SS-V Redline
What if your car doesn't have this magical book? After all, the VY is 16 years old and books seem to disappear with this length of time
I most certainly didn’t get my VY with these magical/mythical books either. They tend to get lost....
stick3
newcastle nsw
on here recommended ecotec oil change at 5k or 6 months holden VS service intervals is 10k or 6 months
vy could be the same as the vz 7500ks or 9months i still have both log books
Whiteshark68
Queensland
As i do have the service book for my Berlina it is indeed 7500ks or 9 months
trautman
tiboborough
vs ute 5.0l auto vs series III v6 5speed
using 50 for him better than a 20 or 30 no one knows how often the dood does changes over time it will turn into 40 then 30
etc just trying to help nothing worse than throwing a leg out of bed nobody here is a millionair
