Engine only running on 4 Cylinders
M5.
Geilston Bay
VX S (5 speed)
Half through a 200km trip the VX dropped cyl 3&6 (no spark). Stopped at the servo natually I offed free advice by another commodore driver who said one of the coil packs had packed it in. I'v swapped over the coil packs, but 3&6 still have no spark.
HELP???
Benny
got the Commodore home 200km ok on 4 cyls.
])R@G()N
VT
Yeah same thing happen to my one (ignition module) 2 days after I got it, lucky it was under warranty. that was 10 years agon and hasn't done it again
cander24
NSW South Coast
VZ GTO. VS LS1.
As above, i'd be checking your dfi module. Also give it an oil change asap as your sump will be full of unburnt fuel which has contaminated your oil.
Cheap6
VP Exec
Maybe check the 'plugs and leads too; one cylinder not firing will kill it's paired cylinder also.
thekid93
brisbane
vt s pack
get ur dfi from a wreckers.... $65 here with 3 coils..
holden wanted like 600+ and 200+ for dif mod and each coil..
