delcowizzid
on holiday
The pushrods could be hitting the holes in the heads or lifter preload up the ****
did you check that theres preload on every lifter? Preload will decrease/clearance will increase as the engine warms.
Problem has only started now that you've replaced the rockers - it'll be something to do with that.
Did you turn the engine over to tdc on the compression stroke of each cylinder before installing each pair?There was preload on every lifter. I have no way of measuring how much. The instructions just said to torque to spec, which I did.
