Cyl 1 pass side almost 3/4, second one in 1/2 - 3/4 third cyl from the front same side about 1/2 or a smidge less.
Putting rocker cover back the pass side as there is nothing I can do myself to increase preload. Leaving driver side off upon advice as to what to do with front most rod and hole.
Edit: there could be around an eighth of a turn more as that first bit of preload is hard to gauge, because it is hard to feel with the Tq W.
I have to stop now as it's beginning to get dark and if I stop now the cursing won't begin. I have the very front lifter left to go on the drivers side, once I work out what to do. I also ended up using Loctite blue on the bolts after removing and cleaning them with a rag and brake cleaner. The threaded holes in the heads may or may not be oily, can't tell.
