acarmody
Donati..Whoa Green
- Apr 29, 2007
- 5,920
- 49
- 48
- Location
- Brisbane
- VX Berlina
Yep I am hopefully going to get my engine rebuilt soon due to a thrown bearing, I thought that while it was out to get the whole engine done. I was just wondering if anyone can spot anything I might have missed or should get done.
Parts:
COMP Cam Camshaft [216°/216° at .050", Intake Lift .317" (.507" lift at 1.6:1 rocker ratio), Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio), 111 LSA]
ACL Race Conrod Bearings
ACL Race Camshaft Bearings
ACL Crankshaft Bearings
ACL Race Pistons with rings (make 10:1 compression)(20 thou over)
ACL Full Gasket Kit
Rollermaster Double Row Timing Chain
Crow Conical Valve Springs
Crow Molychrome Spring Retainers and Collets
ARP Head Stud kit
ARP Main Stud Kit
ARP Conrod Bolts
Some work I will be getting done:
Chemical Clean
Piston Bores bored out to 20 thou over
About 10.5:1 Compression through heads shave (anyone know how much it needs to be shaved?)
Conrods and Crankshaft remachined
Heads tidied up (I've read that the Ecotec heads are quite good, any comments?) and valves reseated
Custom Tune
I dont know about new lifters as my current set were replaced by my mechanic less than a year ago, I just don't know what brand. I can get new standard Crow Cams lifters for $224, but I might just get the rebuilder to check the current ones.
So can you find anything missing? If so any advice would be greatly appreciated.
-Cheers,
Adrian
Parts:
ACL Full Gasket Kit
ARP Head Stud kit
ARP Main Stud Kit
ARP Conrod Bolts
Chemical Clean
Custom Tune
-Cheers,
Adrian
