VSIIBerlinaL67
- Jun 15, 2005
- 988
- 10
- 0
- Age
- 35
- Location
- Melbourne
- VX SS M6
yer should be decent once cooled and up the boost say like 25psi
10psi and my compression ratio is 8.2:1
Just wait till I raise it up to 16psi I should be running low 13's high 12's
Overrated...??? it all adds up at the end KW wise.. H beam Conrods etc etc.. Yes expensive but strong...
Yeah i know they are not cheap... Im in the same boat.. i have a VY 03 ECOTEC MANUAL UTE and its now done 152,000km and im starting to upgrade/replace as things go..
Just did my Excedy clutch last month check my build thread.
How many Kms and what model is you holden mate ????
So really you only have 2K to spend on the rebuild ???
You have H beams conrods????
I havent decided if i want to supercharge or not / stroker it or keep it at a 3.8lt still trying to decide that one..
Was looking at rebuilding my engine to last lifetime too. ARP top notch product.
RIK......
I would consider a different piston to ACL. I've heard of a few cases where the piston exceeds the deck height thus reducing squish.
However if you are getting the engine balanced the pistons should be able to be machined down and weight matched.
Diamond pistons are hot forged powder metal and with some L67 Diamond pistons to get the correct install height should do the trick very very nicely.
INTENSE-Racing.com: 3800 - Hardcore Engine
get your balance shaft removed and block up the oil feed to it. there is lots of oil system mods that can be done to help it last, mine just about finished being built get it back sunday.
well you say you are getting a double row chain. to fit that you need to disconnect the drive to the balance shaft so it will be sitting there doing nothing anyway and oil will be flowing threw the bearing for nothing so just take it out block up the hole and the oil can be used to for important things.
alot of work can be done to the oil system removing restrictions and increasing flow. just need a builder that knows what there doing.
I had a VZ V8 with a mafless tune beat me down the quarter by .139
He's on the left im on the right, I kicked his arse off the line
