Engine Relays - Where to buy, How much?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by greenacc, Dec 13, 2008.
  1. greenacc
    greenacc Searching for the billion
    VE Berlina
    There are 2 types of relays in the engine bay. The big Bosch ones, and the smaller ones for the thermo fan etc. Where should i get them and what do they cost? My low speed fan is not coming on.... and i want to replace all the relays if they are cheap enough.
  2. vsl67
    vsl67 Member
    VS l67 statesman
    I just grabed a heap from the wreckers and keep them as spares most of the wreckers dont even charge for them if your grabing other bits and pieces ,I got some the other day with a set of vs caprice visors for $15
  3. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Swap the relays around to check if it is the relay - if not then it's the coolant temp sensor.
