Engine revving up and down in Park when Airconditioning is on. VZ 190KW.
Twisted77
VR SS & VZ SV6 190kw
Hey All
I have an issue that even a Holden Dealer can't figure out.
When I have my VZ in Park with the Aircon on it revs up and down then idles then does it again over and over.
Any Ideas?:confused:
Hrd455
35
Vz v6 ute
Its probally a sensor, did it throw any fault codes
Ian Johnston
Mount Gambier, SA
2015 Subaru Forester, XR6 turbo ute.
How high are the revs going?? Sounds normal to me.
Twisted77
No fault codes at all which is the problem.
Twisted77
the revs are going upto about 1500 revs then back down
FATMOE
VY Clubsport R8
IAC, and its not normal for whoever thinks it is.
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
that would be a good solution if alloytecs use one....
as said, will be an electrical issue, does the revs cycle with the the a/c compressor cutting in and out?
Ian Johnston
Mount Gambier, SA
The revs should cycle with the AC on, but probably not as high as his is doing, thats why I asked how high they were going.
Twisted77
Hi there
I have just notoced that it doesnt nomatter the gear, D, N, R,P but is more noticeable when AC is on and in Park. When in Drive the car revs and trys to move forward...lucky for the brakes I guess! But even with the ac off it does still rev up and down..
