Engine running lean
Shauno-81
Newcastle
6.0L VE Calais-V.
Quick question, is it actually harmful for your engine if its running lean? Cheers
07GTS
Australia
VEGTS BUILT BLOWN E85
yes too lean will make a hotter environment in the combustion and can kill pistons, thats usually why when a important sensor fails it will default to rich...
Turtle2388
NSW
VE SSV
You can cause the engine to knock/ping and fry valves pistons etc. Not good. Obviously leaner then stock is good but the car must be tuned correctly.
Sent from my GT-I9505 using Tapatalk 2
Turtle2388
NSW
VE SSV
So I guess what I'm saying is, lean s
Is good! It makes power! However.. Too lean can be catastrophic.
07GTS
Australia
how lean are we talking..? highway cruise lean or bad lean..?
Turtle2388
NSW
VE SSV
Lol I'm not informed enough to give an opinion. Best be talking to a tuner.
RoaringSky
VE SSV MY9.5 Manual Sedan
At idle and cruising, the air fuel ratio should be aimed at 14.7:1, that's the perfect mixture. Under full load, depends on your mods etc, around 12 or 10:1.
RoaringSky
Yeah depends on the mods I guess, as well as the air temp and humidity at the time of the tune, need to allow for cold weather if tuned in summer. Most of the cars I had were tuned at 12:1.
Turtle2388
NSW
VE SSV
What's stock under full load and light load etc??
