Woodsman444
- May 20, 2015
- 128
- 6
- 18
- Age
- 64
- Location
- Perth
- VE Calais sedan 2008
What happens if the four cam shaft sensors do not talk or line up with the crank angle sensor? what is likely to happen with the engine running?
Second question: If after the crank angle sensor has been replaced the same code keeps popping up on the scanner,why would this happen?
Third question: Would or can my ECU have an intermittent fault and is it possible to buy the crank angle sensor plug?
