dassaur
- Jun 10, 2020
- 1,268
- 1,144
- 113
- Location
- Sydney
- VF Calais V V8 Wagon
I've decided I'm going to DIY some engine upgrades. (L77). I want to be able to say to myself, 'yeh, I did that'
I still need to speak to my tuner, but this is what I'm planning:
items added due to members:
Other misc such such as head gaskets, front timing seal gaskets etc, hb bolt etc.
It's already got CHE trunnion bearings.
Plan is to remove ECU, take to tuner, flash a theoritcal suitable tune, reinstall & then drive it to him and put it on the dyno for a full workup. Should be able to hit 7000rpm easily.
I welcome all thoughts and comments, suggestions to make it easier and tips and tricks to installing!
My plan is to do it in the car. Remove radiator, swing condenser out of the way. Drop sump a little by undoing engine mounts, jacking engine and chocking with wood.
I'm in no rush to do it so I've got alerts on amazon & other US retailers set up, hopefully I can get some good prices. By my calculations the parts & machine work will be around $4-5k
Lunati camshaft - 219/223 .612/.615 112+1218/226 .598”/.598” 112 +2 from cam motion- Machine work on the heads (machining chamber to 64cc) and install springs (dual PAC .660 platinums)
- Rollmaster timing chain kit (single row CS1190)
- 3 bolt arp cam bolts ARP 134-1003
- LS2 chain dampener (12588670)
- LS3 Valley plate (12599296)
- LS3 PCV hose 12599298
- Melling m295 oil pump
- Delete the oil pressure relief in the sump (GM 96041864 fits perfectly)
- ARP head bolts 134-3610
- Pushrods to suit (wont know until I measure) (ended up being 7.3" went with manley CrMo)
- GM buckets 12595365
- Johnson (the real ones, not hylift johnson) 2110 lifters
- Powerbond regular HB HB1117N
- Balancer bolt 12557840
- Cam retainer plate 12589016
- Head Gaskets 12610046 x2
- Timing cover gasket 12633904
- Crankshaft seal 29602
- Intake manifold gaskets ACDELCO 19256623
- Oil pan gasket 12612350
- Water pump gaskets 251663
- Oil pickup brace/additional bolt
