Hillsy1
- Feb 26, 2021
- 1
- 0
- 1
- Age
- 46
- Location
- Bendigo
- VL 3.0
I recently had a injector seal leak so I got the injectors cleaned and replaced the seals. The rb30 fires up 1st kick but had a vacuum leak. I bleed the cooling system and turned the engine off. The vacuum leak was from not connecting the vacuum line to the throttle body so I reconnected it. Now the engine will not start. I use start ya basted and it fires up. I then remove the return fuel line from the fuel rail and crank he over and no fuel is coming out. Inlet fuel line has really good pressure and I've gone as far as hooking up a 2nd distributor and I can hear the injectors working fine. Can someone please help me with this problem b4 I put the vl in the crusher. Cheers.
