Engines
Discussion in 'General' started by TRuchaldo, Feb 12, 2007.
  1. TRuchaldo
    TRuchaldo New Member
    1998 holden vt
    hey guys
    i got a 98 holden vt and i was wondering if anyone knows where to get new engine? or how much it would cost to recondition or which place to go?
    thanks
  2. Spaced
    Spaced New Member
    1997 VS Commodore Exec
    Why do you need a rebuild? How much you want to spend on a rebuild will give you an idea of what you can get. For example a standard rebuild will run to 2k. You could get a second hand motor for a lot less or maybe a later model crate engine and then modify the computer to suit. Or you could get a rebuild from come? Or you could speak to our new sponsors yella terra (see below in the forum) and tell em your budget not including labour and go from there.
  3. TRuchaldo
    1998 holden vt
    cool well my engine has 196 0000 kms so i wanted to recondition it
    how much would that cost?
  4. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Just because it has done a few k's there is no need to rebuild it. Do a compression test and an oil consumption test first, if they pan out ok, don't fix what ain't broke.
  5. calais_304
    calais_304 New Member
    98' VT Calais s1 - 195i
    oh mate she's still fresh, don't worry about recon it yet, if anything start adding mods till that kills it:thumbsup: then chuck in a G3:D
  6. TRuchaldo
    1998 holden vt
    oh cool guys
    thanx for the help
  7. naf33n
    naf33n go
    The Shire
    Supercharged VU SS
    196000kms. mate the motor has only just run in. still alot of flogging left in it.
    its the little thing you have to worry about. alternator, waterpump, steering pump. they usually **** themselves long before the motor
  8. Spaced
    Spaced New Member
    yeah the gearbox will sh!t itself before that. Just remember regular servicing and she'll be fine. Naf33n is right the extra's will crap out before the motor will the ecotec's a bloody well built engine.
  9. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Just make sure it never overheats, it's the biggest killer of the ecotec.
