Eprom/eeprom Erasing & Size's ?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by ragex, Nov 21, 2006.
  1. ragex
    ragex New Member
    can a normal UV light thats on the cieling of my garage work to erase my eprom?
    also can i just get a eeprom instead of a eprom?
    i have a 27c128
    what would i have to get in the range of eeprom ? bigger better?
    aparently they can be erase with a programer with out a UV light?
  2. hakhawk
    best one to get is a 29c256, allows you to use the vr code if you want, and can still use vn code with no problems. but, good luck finding one thats a 28 pin, otherwise you have to rearrange some pins on the 32 pin versions.
    ive opted for a 28f256, its a 28 pin but still have to swap 2 wires around, but at least it fits under the blue cover.
    what sort of uv light is it? one of those ones that looks purple/black? im pretty sure it has to be a unfiltered uv light, the sun will do it, but take like a week, you can get uv erasers, but its much cheaper and easier to get a eeprom. cost about $5 each from www.futurlec.com.au for my 28f256
  3. VN_Luke
    VN_Luke ƃuoɹʍ ʇsnɾ sı sıɥʇ
    Mexico
    Get in the ute
    you can use a toothbrush cleaner from jaycar, with slight modifications to keep the UV light on :)
    i've been using one for months now!
    jaycar cat #: GH1507
    $9.95 :)
    cheapest EPROM eraser i've seeeen!
    Luke.
