Mate....Look into the Etch Primer ...It is originally supposed to be used to etch into the aluminium to get the paint to stick..Otherwise u cant paint alloy surfaces very effectively at all......
You dont need to etch prime any steel.........Standard primer, undercoat will do the trick...........
You have to be aware that the primer hardens up over time....and is poreous, so it absorbs moisture out of the air....even 2k highfill primer....
Where most people run into trouble....is that they let the undercoat set to long before top coat application......48hrs max....escpecially when painting with Group 3 colours and custom tints...
You dot need to etch prime mild steel SIMPLE
If you are painting Alloy however...HELL YEAH ETCH PRIME THE CRAP OUT OF IT....
