excelerator depresses itself
monsoon
vx ss commodore
Hi
i Drive a VX 6 speed ss commodore ,the problem im having is when i hit a "Dip' in the Road and excelerate out of it or going around a steep corner (and excelerate )The "Pedal " depresses itself Hard ! even when ive taken my Foot off it . has anyone experienced this themselves ? any ideas what could be the Problem? could it be the Engine Mounts??
hope you can understand the Question.
Thanks for any help.
regards,
alan.
M
MzTomboy
Guest
Same thing happened to my brother in his VK calais... a mechanic checked it out and couldnt find anything wrong and lubed up the cable behind the peddle.. a week later he ended up wrapped around a pole and wrote off the car.. he was VERY lucky to only need plates and pins in his wrist, so be extremely careful and have it checked out properly!
monsoon
vx ss commodore
'Wow' ok glad he wasnt too badly hurt.
i also noticed when driving around 80 KPH then give it a Burst .. the excelerator pedal vibrates too!.
monsoon
vx ss commodore
Hmm dunno..Leave traction on / Off??
Boonz
Donating Member
33
berri, south australia
green 355 VG ute
how about you take out the cruise control relay cos sounds like the cruise control motor is winding the throttle open! if it is doign it again after the relay is removed then it is elsewhere.......
The Sicilian
Ironically work for Ford
VX Commodore S V6 5M
yeh sounds 2 me u gotz a cruise control prob if u feel tha pedal vibrating
monsoon
vx ss commodore
ok thanks guys ..will try that.:)
monsoon
vx ss commodore
hi again
took out the cruise control relay ..still doing it ..any other ideas please ?..took to mechanic ,auto electrician ..no answers as yet.:bang:
Pretender
Brain function fading .
54
Sunny Rockingham WA
Pajero LWB Wagon, Power/economy what's that ???
monsoon said:
Hi
regards,
alan.
Just to clarify, is the pedal actually going down further or just staying down when you take your foot off?
If it's staying in the one position it could be as simple as the cable sticking or an obstruction in the throttle body (eg dirt build up or part of your air filter etc).
Apart from the cruise control there should be nothing electronic that would actually open the throttle more, I may be wrong as I'm not up on the electrics of your model, but I'd hope that there would be nothing else.
If it is opening the throttle further then sorry I have no suggestion other than the cruise is faulty but you have already disconnected it.
