exhaust back pressure needed. a myth? :poke:
IMCRZY
YO!
Wollongong
88 VL Excutive Turbo, 00 VT Olympic Edition
Velocity is what is needed, to big and u will loose & to small u will loose, just need to fing the right setup
GenReaper
Donating Member
Radelaide
www.AusHeli.com
VY SS Series II Wagon
I dropped my exhaust to straight collectors on the dyno and it lost stack of bottom end torque.
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
As the first guy said.
You don't need backpressure. But that doesn't mean you can run 5" pipes and it will be a missile.
You need a balance between exhaust gas flow and gas speed.
Genreaper would have lost a fair what of torque because the exhaust system wasn't there to continue drawing the spend gas from the manifolds. So it essentially slows it down making the engine work harder.
In very basic terms anyway.
edals
Well Ever since i put a exhaust on the VX, Its only a 6, It cannot make its mind between 3-4th, so goes in between gears at about 75kms going up a slight hill, never did with the old restricted exhaust so i have lost some torque down low.
AirStrike
91' VN SS
With a turbo setup being the exexption to this.
STEEV888
34
central coast
'95 200sx.
i know about velocity and everything.
which is why i was planning on getting a 2.5 instead of a 3 when i went exhaust shopping.
but this opened up ideas that a 3" system would be better especially considering this car was stock and mine will have mods slowly done to it over then next 2 - 3 years.
one of the first being exhaust otrcai tune etc
and when i took my cats out i got more power all through the rev range as well as a faster 0 - 100
AirStrike
91' VN SS
From what I have seen and read about the LSx series of engines, a mild 5.7lt is best with the twin 2.5", only go twin 3" on the 6lt+ engines or if you are running FI, etc.
soop
Banned
Smithton, Tasmania.
That or a really big cam in a 5.7.
They just don't physically move enough gas to warrant a twin 3". Lots of people will argue till they're blue in the face about that though.
