exhaust drones in hot weather
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by lockmac, Dec 19, 2007.
  1. lockmac
    lockmac New Member
    just wandering what is the reason for my exhaust droning in hot weather? and is their any way to stop this.. my friend said install a thermo on it which will stop it but i really dont know what this is.
    Also.. i have the stock exhaust... im almost thinking about putting that back on instead of my red back as even a slight amount of drone can annoy me... could i perhaps mix mufflers with the two exhausts and would this decrease some of the drone but keep it at a nice note? if not ive been suggested to get a chambered muffler on this forum........
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    The exhaust note changes when hot because the flow characteristics change. It will flow a bit faster and the exhaust expands slightly as well. Do you have a rear resonator? If not, put a perf tube hotdog on the rear. If you have, then the only way to change the note is to change the front muffler to a different design, I have a chambered front muffler and a hotdog on mine and it doesn't drone.
  3. lockmac
    lockmac New Member
    hi i just went down to the exhaust shop and he rekns putting a chambered muffler in the front would loose a bit of power... he did suggest putting sound dampening material in the boot, which should help as that is a large cavity... do you think this would work? i went to bunnings and they only had the acoustic deadening stuff that you put in your walls... maybe this would work?
    many thanks
  4. bradcad
    bradcad New Member
    VT Berlina & mazda 2 DE
    I would imagine the slight power loss from a chamber muffler would be negligent. Not anything you would notice I dont think
  5. dufus
    dufus Donating Member
    rickshaw
    I doubt that you will notice any difference in power because of the chambered muffler.
  6. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    You may find you actually gain a bit of bottom end.
