azzfox
Braaap.
- Sep 5, 2005
- 1,388
- 21
- 0
- Location
- Yarra Valley, VIC
- Website
- www.facebook.com
- VE SS-V
Hey all. I have bit of an issue with an exhaust I picked up a while back which I finally fitted. It was previously fitted to a VN, but for the life of me I cant figure out how the tip bolts up! The stock exhaust as most of you would know has a metal hook welded to the tip that threads through the two rubbers. BUT, this exhaust likes to sit right up against the car and welding a 'hook' on is not an option.
As you will see in the pic below there is a bracket welded to the side, which had a bolt through it. But theres nowhere on the car for it to bolt up to! Maybe there needs to be a bracket of some sort welded to the car? Does anyone have this style exhaust fitted to their car?
Maybe I could use a rubber that goes from one mounting hook to the other, which the exhaust would rest on? Anyone know where I could find one? It would need to be a firm fit. There is a rubber pad mounted to the car above the exhaust so it wouldnt bang around.
Btw, the cable ties are temporary as the car isnt being driven yet.
