VK SL 3800
Got this really annoying noise coming from somewhere in the exhaust i think, its really hard to track as it only sometimes does it and only at idle and soemtimes when you first touch the throttle. Sounds sort of like a hissing ring/ metallic ring if that makes sense. Never when cold, when you pull up sometimes and its really loud and then goes away after about a minute of idling, so when you get out to have a poke about it goes away before you can find it, with the bonnet shut it sounds like its coming from underneath level with the doors, bonnet open sounds sort of everywhere on the carbie/ manifold side, but the manifold gasket is not leaking for sure.
Any ideas?
Any ideas?
